Activity › Forums › Adobe Premiere Pro › Which Codec to use
  • Which Codec to use
    Posted by Hawkmaster on December 12, 2006 at 1:05 am
    I’m using MPEG video down loaded from a Sony Handycam. Which editing mode would work best, and if I select “video for windows”, which compressor should I use when initially setting up my project?
    Roger
    Mike Velte replied 19 years, 9 months ago 3 Members · 2 Replies
  • Harm Millaard
    December 12, 2006 at 9:39 am
    MPEG1 or 2 or 4? What size, multiplexed, audio format, from what camera, and what do you want to do with it? Just a couple of questions to understand what you are trying to accomplish.
    BTW, MPEG is not really suited for editing.
    Harm Millaard
  • Mike Velte
    December 12, 2006 at 11:51 am
    Your best bet is to get a Analog/Digital converter and capture thru that, converting the analog out signal from your camera to digital video. ADS Pyro AV Link is about $130 at B and H Photo Video. The results will be much better than trying to edit already highly compressed files.
