Activity › Forums › Apple Final Cut Pro Legacy › Which Apple Laptop for HD?
  • Which Apple Laptop for HD?
    Posted by Max Baker on January 14, 2010 at 5:25 pm
    I am contemplating dipping my toe in the Apple waters, and want to buy a used Mac laptop for HD video editing and production. I have not so much as turned on a Mac, so I know nothing about them. What Mac laptop could I consider as a minimum that will handle HD, as in model, CPU, OS, clock speed? I am very mobile in shooting and editing video, so I really need a laptop. Prefer starting out with used, until I know I want to make the plunge. Curently using a Dell laptop with core 2 duo and Vegas Pro 9.0. Many thanks!
    Max
    Max
    Bj Ahlen replied 16 years, 8 months ago 4 Members · 4 Replies
  • Steve Eisen
    January 14, 2010 at 9:11 pm
    Look at the MacBook Pro.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Bj Ahlen
    January 14, 2010 at 9:42 pm
    The 17″ MBP with an LED 1920×1200 matte screen is flat-out stunning, and it has an ExpressCard slot that can be used for eSata high performance disk access (much faster than FW800 even), and it also has a high performance graphics card that will help you for Motion especially.
    Look for one with a 320GB disk or whatever is one or two generations behind on the disk size.
    Factory refurbs have the same warranty as new (1 yr P&L), and you can add 2 years to that inexpensively anytime before the first year is up. Apple.com has these, also MacMall.
    Do not get a “MacBook” (without the Pro), they don’t have usable graphics cards and there are a few other issues as well.
  • Al Bergstein
    January 15, 2010 at 4:15 pm
    I’ve got a MacBook Pro Intel Core 2 Duo 2.4 GHz. It’s fine for Logging and Transfer, but the main problem is that it is only capable of 2 GB RAM. The newer Macs go beyond that but you lose the Express slot, which is very useful for many add ons. I agree that you need more than the 160 GB HD. Not sure that you will save that much by buying used, since if you get a 160 GB drive you will probably need to upgrade it quickly with HD footage needs. I found I needed a quad core desktop Mac to really do the job right, but a MB Pro might get you down the road for a while, and prepare you for doing more taxing work later.
    Alf
    Panasonic HMC-150 & FCP on MacPro Dual Quads, 12 GB 7.0.1 on 10.6.2
  • Bj Ahlen
    January 15, 2010 at 5:50 pm
    As I stated above, the 17″ MBP keeps the ExpressCard slot.
    The newer MBPs take up to 8 GB of 1066 MHz DDR3 RAM.
    I use a FirmTek eSATA dual drive enclosure, rock solid and high performance, which saves me worry about the system drive filling up.
