Activity › Forums › Apple Final Cut Pro Legacy › Where’s the RT drop down options?
  • Where’s the RT drop down options?
    Posted by Justin Gray on October 13, 2005 at 1:44 am
    I am fairly new to FCP 4.5. That said, I have a handful of Quicktimes I have created at different points in the past; some from Discreet’s Edit*, and some from Premier 6.5. When I put most of these clips into a FCP sequence, the RT options are not available in the RT timeline drop down window. Do the clips have to be captured in FCP in order for these settings to be available? I have made sure to change the sequence settings to match the clips properties, i.e aspect ratio, compression settings, audio sample rate etc. But why can I not change my RT settings from the little timeline drop down menu? What gives? Thanks fellow Bovines. -Justin Gray
    John Pale replied 20 years, 11 months ago 2 Members · 1 Reply
  • John Pale
    October 13, 2005 at 4:20 am
    The drop down menu only appears in codecs that are supported by RT Extreme.
