Activity › Forums › Maxon Cinema 4D › Where’s the render tag setting?
  • Where’s the render tag setting?
    Posted by Manny Rellesiva on July 17, 2007 at 12:02 pm
    I was following a tutorial when I encountered this step:
    “In the Render Tag setting select the Object Buffer tab and enable Buffer 1.”
    Im a newbie in Cinema 4D 10 and im using windows xp pro. Where shall I find it? thanks in advance
    Adam Trachtenberg replied 19 years, 2 months ago 3 Members · 2 Replies
  • Samir Kharchi
    July 17, 2007 at 12:16 pm
    you find the settings in the Attributes Manager aka AM. You will generally find almost all settings in the Attributes Manager. Isn
  • Adam Trachtenberg
    July 17, 2007 at 1:34 pm
    That must be an old tutorial. The object buffer settings are now found in the compositing tag.
