Activity › Forums › Apple Final Cut Pro Legacy › Where’s the audio on MPEG-2?
Posted by Alexander Gao on December 28, 2005 at 1:31 amI used compressor to encode my project to MPEG-2 video. How do i get audio with it? Is this possible??? I’m very confused.
Thanks, Alex.
Chris Poisson replied 20 years, 8 months ago 4 Members · 6 Replies -
Simon Webb
December 28, 2005 at 5:30 amIn Compressor, you must encode the audio separately if you’re encoding into mpeg 2 for DVD projects. Check the menu under “Setting”, you’ll see that you have a number of choices. As a rule of thumb, I usually refer to the manual for instructions if I’m unsure.
Alexander Gao
December 28, 2005 at 4:53 pmso how do i sync the audio with the video on a dvd?
Alexander Gao
“When the revolution happens, I’ll be leading it.”
Simon Webb
December 28, 2005 at 6:03 pmDVD Studio Pro does this automatically. All you have to do is drag both the mpeg 2 file and the audio file on to the track. However, if you’re using iDVD, what you should do is export your sequence in FCP as a QuickTime movie (video and audio), then drag that movie into your iDVD project. iDVD will do all of the encoding for you.
Chris Poisson
December 28, 2005 at 6:04 pmWhen you encode the video and audio with the same ins/outs the sync is automatic. You just throw them in the track.
Have a wonderful day.
John Fishback
December 28, 2005 at 7:25 pmWhen you export from FCP set your in and out points and then export two files – one is QT video only and the other is aiff audio only. Export reference files to save space. Then use the ref files in Compressor. Convert the video QT file to mv2(mpeg2) and the aiff audio to ac3.
John
Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
Dual Cinema 23 Radeon 9800
FCP Studio 5
Huge U-320R 1TB Raid 3 firmware ENG15.BIN
ATTO UL4D driver 3.50
AJA IO driver 2.1 firmware v23-28
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors -
Chris Poisson
December 28, 2005 at 9:40 pmHey John,
You live in my hometown, how’s business there? E-mail me off-forum, poissonsaz@qwest.net.
