Activity › Forums › Adobe After Effects Expressions › Where to place expression?
  • Where to place expression?
    Posted by Paul Ducco on February 10, 2023 at 12:08 am
    Howdy Brainstrust,
    I’m wondering where and how I can get an existing preComp, placed in the mainComp, to scale if a marker is set on the preComp Layer (in the mainComp).
    The context for this is hoping to be able to create a functional version of this that a team can use…i.e, not requiring expressions to be added each time the preComp is placed.
    Is there a way to do this with expressions alone, or am I looking more at scripts etc?
    If the latter I’m very keen to learn more…where do I start
    Cheers in advance
    Filip Vandueren replied 3 years, 7 months ago 2 Members · 3 Replies
  • Filip Vandueren
    February 10, 2023 at 2:18 pm
    The expression needs to be set up where it is used, so on the scale of the layer in the main comp.
    New pre-comps could be replaced into the main comp instead of added, and that way the expressions and other settings/effects that are in place remain, is that an option ?
  • Paul Ducco
    February 13, 2023 at 3:28 am
    Hi Filip, thanks.
    Unfortunately, as this would be a widely used ‘toolkit’ there wouldn’t necessarily be the option to have precomps existing in a.mainComp to be swapped.
  • Filip Vandueren
    February 13, 2023 at 10:38 am
    In a pinch, an adjustment layer with the transform effect could affect the precomp if it’s placed beneath it.
    But again that’s not idiot-proof…
    Maybe just structure the project as a template, where the team can only add footage in a media precomp, and that precomp is used elsewhere with the right expression set up?
