Activity Forums Adobe After Effects where is the brightness panel and how can i key out unsafe areas?
  • where is the brightness panel and how can i key out unsafe areas?
    Posted by Sophie Watson on January 30, 2007 at 7:15 pm
    this is a stupid question but i just can’t find where to adjust the brightness of my sequence in AE 7. i have searched tutorials but it must be so obvious nobody bothered to explain.. i am most confused..
    also i wish to find out how to key out the unsafe areas and specify the maximum signal amplitude as the last time i tested it on a tv it looked about 6 billion times too bright..
    thank you in advance for your advice.
    Kuaishou replied 19 years, 7 months ago 2 Members · 2 Replies
  • Sophie Watson
    January 30, 2007 at 10:54 pm
    thanks also for this.
    i was hoping for something like in FCP where you can tell it to tell you where the overly bright areas are and you can adjust by looking. as you can probably tell i’m not really a numbers person, but your method makes some sense so i will try that. thanks.
  • Kuaishou
    January 31, 2007 at 4:30 am
    hi…doesnt colour finess have this scope?…i seem to recall it can display waveform and vector scope…though i dont know how accurate it is…cheers…merv
