Activity Forums Adobe After Effects Where did “Alpha Levels” go in AE CS5.5 ???????
  • Where did “Alpha Levels” go in AE CS5.5 ???????
    Posted by Doug Nash on July 10, 2012 at 9:45 pm
    Seriously. I’m either going blind, or they renamed the damn thing, or it just doesn’t exist.
    I can’t find that old trusted filter, ANYWHERE in CS5.5 Mac.
    But…here’s the weird thing. It works fine if import an older project in. The plugin is there and works like always. I just can’t find it up in the “Effects” pulldown, like where it should be. So, if it works by importing an older project, then the plugin MUST exist in CS5.5.
    Please help me stop the insanity!
    Thanks.
    Doug Nash replied 14 years, 1 month ago 2 Members · 3 Replies
  • Adriano Moraes
    July 10, 2012 at 10:11 pm
    Hi there!
    According to the AE documentation:
    “The Alpha Levels effect has been removed. Instead, use the Levels effect, which can be assigned to work only on an alpha channel, has a histogram, and is a 32-bpc effect. Old projects that use the Alpha Levels effect will still open, and you will still be able to modify the Alpha Levels effect properties in these projects: Levels effect”
    Hope it helped.
    Cheers!
    ninguem
    ////https://cargocollective.com/ninguem/
  • Adriano Moraes
    July 10, 2012 at 10:14 pm
    Sorry here´s a working link:
    https://help.adobe.com/en_US/aftereffects/cs/using/WS2bacbdf8d487e582318b176312ea63a9b11-8000.html
    Cheers!
    ninguem
  • Doug Nash
    July 10, 2012 at 10:17 pm
    Wow! Thanks so much. That answers everything.
    Cheers!
