Activity Forums Boris FX Particle Illusion Where can I get IllusionRender? (It ain’t on my v.3 disk!)
  • Where can I get IllusionRender? (It ain’t on my v.3 disk!)
    Posted by Chris Elkins on November 13, 2006 at 8:01 pm
    I see the answer to my post below is to use IllusionRender. It didn’t come on my pIllusion 3 disk. How do I get it?
    I did find the option to run pIllusion in software render mode, but it still limits the output to the stage size.
    Chris
    Aharon Rabinowitz replied 19 years, 9 months ago 2 Members · 3 Replies
  • Aharon Rabinowitz
    November 14, 2006 at 4:58 am
    It’s been a long while since I installed, but I think it installs itself when you install. Check your pIllusion folder to see if it’s already in there.
    If you’re on windows, it should be in the same start menue folder as the pIllusion shortcut.
    Not sure about mac.
    Truth is – not sure about any of this… Been soooooooo long.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Chris Elkins
    November 14, 2006 at 12:34 pm
    I have looked and it is not there. It’s not in my program group from the start menu, nor is it in the C:\Program Files\particleIllusion_3 folder. I have the pale green boxed install cd (particleIllusion 3.0 Indows XP Home/XP Pro/2000 Pro etc..) and have explored it entirely and there’s no hint of a rendering program, nor is it mentioned in the instruction manual.
  • Aharon Rabinowitz
    November 15, 2006 at 3:45 am
    contact support(at)wondertouch.com
    Aharon Rabinowitz
