Activity Forums Apple Final Cut Pro Legacy where can I find good burn in and ink blot transition effects???
  • where can I find good burn in and ink blot transition effects???
    Posted by Nick Natteau on September 2, 2010 at 5:55 pm
    I’ve already been to digitaljuice, shutterstock, and also googled but haven’t found any good results yet.
    I’m looking to acquire some good luma matte transition effects like film burn ins, ink blot stains and spills, etc like this:
    https://vimeo.com/12090666
    I know that After Effects has some plug-ins, but I use FCP and Motion. Would in eed AE for this?
    Thanks in advance,
    – Nick
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Craig Russillroy replied 16 years ago 6 Members · 8 Replies
  • 8 Replies
  • Nick Natteau
    September 2, 2010 at 5:56 pm
    Not sure why, but the link just sends me back to creativecow.
    The video is here:
  • Nick Natteau
    September 2, 2010 at 6:29 pm
    Well, I was hoping I could just find some good mattes. Could you recommend any web sites where the work is already done and I can just drop it into the timeline?
    Thanks in advance,
  • John Fishback
    September 2, 2010 at 7:28 pm
    CoreMelt has some as does Nattress’ Big Box of Tricks. Checkout VidroCopilot’s site for organic effects, etc. Some excellent tutorials there, too.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Brian Pitt
    September 2, 2010 at 8:09 pm
    Motion has a few of theses built in the program. Just open up the program, and go to the library tab and type “ink” in the search box. You can do the effect in motion, or drag the .mov file into your canvas and then export for use in another program. Hope that helps.
    Brian
  • Nicholas Natteau
    September 2, 2010 at 9:27 pm
    Hi everyone and thanks.
    Thanks Brian. Yes, actually I’ve been using those in Motion but it seems that if I need to increase their size, it affects their speed. In Motion, if I increase the ink brush stroke to say 100, the speed becomes choppy. It becomes msooth again if I reduce the size of the stroke.
  • Brian Pitt
    September 2, 2010 at 9:42 pm
    Maybe try exporting at the stroke size that looks the best and then upconvert that file using compressor or mpegstreamclip?
    Brian
  • Mark Suszko
    September 2, 2010 at 9:54 pm
    Digital Juice has a tutorial on the sherlock holmes look and they have LOTS of ink blots, did you look in the right places? If rolling my own, I suggest using chocolate sauce over ink; cleans-up easier and smells better too.
  • Craig Russillroy
    September 3, 2010 at 6:35 am
    Hi there !
    Go have a look at video co-pilot dot net , andrew krammer has made a few DVDs with just what you are looking for – hope this helps ..
