Activity › Forums › Apple Motion › Where are my Standard Def presets in Motion?
  • Where are my Standard Def presets in Motion?
    Posted by Mike Weber on January 17, 2008 at 5:29 pm
    I am using Motion 3.0.2 on a G5. For some reason I am missing my standard definition project presets. For example if I go the Motion menu >> Preferences… >> Presets, only high definition settings show up for either Project presets or Export presets. I see DVCPro HD, several HDV, a bunch of XDCAM, and that’s it.
    I’ve been using the standard def 8 bit uncompressed and DV NTSC setting just fine on our other workstations. Why are they not showing up on this one? Is there some check box I’m missing, or do I need to get drastic and reinstall? Thanks-
    Mike
    Mike Weber replied 18 years, 8 months ago 1 Member · 1 Reply
  • Mike Weber
    January 17, 2008 at 7:08 pm
    OK, I did a search and found someone had a similar problem earlier, where they had no presets at all. Followed a link to this Apple doc describing the problem:
    https://support.apple.com/kb/TS1097
    I did what it said (uninstalled & reinstalled Motion & Compressor), and that fixed the problem.
