Activity › Forums › Maxon Cinema 4D › Where are “Make Preview” renders saved?
  • Where are “Make Preview” renders saved?
    Posted by Rob Mason on July 24, 2019 at 8:50 pm
    I want to use one of my “Make Previews” in After Effects for general timing without having to render the full quality render which will take too long. Where are these stored?
    Is it possible to obtain the same low level of quality render to the Picture Viewer?
    I’m on a Mac.
    Any help is greatly appreciated.
    Brian Jones replied 7 years, 2 months ago 3 Members · 4 Replies
  • Brian Jones
    July 24, 2019 at 9:51 pm
    inside the C4D folder or in the Maxon preferences folder, if I recall. Jim will be able to check. But with the preview movie open in the Preview window you should be able to do a Save As… from that window to save it where you want.
  • Jim Scott
    July 24, 2019 at 10:58 pm
    On my Mac the “Make Preview” file is saved in the same path as other renders: Render Settings > Save > File…
  • Rob Mason
    July 24, 2019 at 11:05 pm
    That did it! Thanks!
  • Brian Jones
    July 24, 2019 at 11:59 pm
    ah yes and maybe the ones I was thinking of with no Save path set…
