Activity › Forums › Adobe After Effects › When you have imported a photoshop file as a composition is it possible for it to automatically update new Layers in the composition?
  • When you have imported a photoshop file as a composition is it possible for it to automatically update new Layers in the composition?
    Posted by Daniel Haskett on May 2, 2005 at 11:43 pm
    Hi there
    I know in AE that when you press Edit Original you can edit the layer you are working on, but if you have a photoshop file and add a new layer to it, how can you add this new layer to the composition that AE has created from the photoshop file automatically? Or is this not possible, do you have to import the layer separately and then just put it in the composition? I know it seems like a trivial question, but it would definetly save time 🙂
    Cheers
    Dan
    Mylenium replied 21 years, 5 months ago 3 Members · 2 Replies
  • Serge Hamad
    May 3, 2005 at 2:06 am
    Hi Daniel,
    I don’t think it’s possible. You could create a couple of empty layers though, right before you import your PS file. This way you could use the reload option in AE. That’s what I do when I know that I will be adding some layers to a ps file/comp.
    Hope this helps.
    Salut.
    Serge
  • Mylenium
    May 3, 2005 at 4:53 am
    Nope, can’t do. All references to layers have to already exist. Anyway, I don’t think that it would be wise if AE always updated things. It may not look like that, but there’s a reason it doesn’t continuously check and import new layers.
    Mylenium
    [Pour Myl
