Activity › Forums › Apple Final Cut Pro Legacy › When we edit to tape, the video lags audio.
  • When we edit to tape, the video lags audio.
    Posted by Bernardo Martinez on December 21, 2007 at 8:59 pm
    Original material ingested from tape, the video and audio are in sync.
    Playing a sequence from the timeline, audio and video are sync.
    Crash recording to tape, audio and video are in sync
    OSX 10.4.11
    FCP 6.0.2
    Kona 3 Card
    Kona Driver 4.0
    AJA GEN10
    HDW-2000 Deck
    Sequence Preset 1080i 29.97 422 ProRes (HQ)
    Capture Preset 1080i 29.97 422 ProRes (HQ)
    Play back Preset 1080i 29.97 8bit
    We are using Playback settings for Edit to Tape.
    Gus Falconi replied 18 years, 8 months ago 5 Members · 5 Replies
  • Phillip Van west
    December 22, 2007 at 1:53 am
    Bernardo,
    Did you do an audio mixdown before the ETT? If not, give that a try. Even if you’ve done nothing to the audio or video, it can solve some weird problems…hope it helps.
    pvw
    Phil Van West
    Terra Nova Productions
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / OS 10.4.11 / FCP 6.0.2 / QT 7.3
  • Arnie Schlissel
    December 22, 2007 at 5:54 am
    When you edit, are your speakers connected to the outputs on the Kona? IOW, how do you know that the edit was actually in sync?
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • John Christie
    December 22, 2007 at 9:25 pm
    Make sure you don’t have the system sound output set to the Kona card, that’s always caused us sync issues.
    Cheers
    John Christie
    Keyframes Editing
  • Bernardo Martinez
    December 22, 2007 at 11:32 pm
    Well the clients are not on site to try some of these suggestions out. One thing they did tell me is that everything works fine with a previous system they have MacPro with a previous version of Final Cut (they did not take note of the version). So I am guessing it has something to do with FCP 6.0.2 or 10.4.11 which is required for FCP 6.0.2
    thanks for the replies. Will keep everyone posted after we do some test next week.
  • Gus Falconi
    January 4, 2008 at 12:13 am
    Im having the exact same issue
    In overall when playing a sequence in the timeline, using an external monitor, the first second is in sync, then the video starts to slow down a few frames and the audio gets heavily out of sync.
    This is only happening in the external monitor. The video in the canvas or viewer is in sync.
    I have already installed more than 20 Konas LHe and this is a first.
    I already tried the following:
    – Updating to Leopard
    – Formating my Mac Pro
    – Installing/Uninstalling Kona Drivers
    – Running software update
    – Using a different, cable, breakout box, monitor, DVCPRO Deck,
    Thanks in advance for your support.
