Activity › Forums › Adobe After Effects › When the Ghostbusters aren’t available, who do I call… Pls help.
  • When the Ghostbusters aren’t available, who do I call… Pls help.
    Posted by Charles Amadori on February 4, 2006 at 4:05 pm
    Hello –
    I have been using AE 6.5 Pro on a P4HTextreme 3.4Ghz, 4GB RAM, Nvidia GeForce 6800 GPU. For the past few days it keeps crashing… I mean it crashes even before I can get started. When I click to import a file the program instantly closes. I thought maybe it was a 6.5 issue, so I tried my old 6.0 and the same thing happens. I then tried disabling Norton Internet Security while running the program in case of conflict and it still crashes.
    Can anyone recsue this poor AE Neophyte? A very important job depends on it.
    Thank you to any Guru’s who can enlighten me in a advance.
    Chuck
    Tim Kurkoski replied 20 years, 7 months ago 3 Members · 3 Replies
  • Al
    February 4, 2006 at 5:51 pm
    what is the crash? does it freeze? is there an error msg?
  • Charles Amadori
    February 4, 2006 at 6:18 pm
    Someone sent me a message that solved the problem… All I had to do to fix the problem was remove the OpenGL3D .AEX file from C:\program files\adobe after effects 6.5\support files\plug-ins\standard\extensions. Apparently there is a conflict with my video card.
    Chuck
  • Tim Kurkoski
    February 6, 2006 at 10:52 pm
    Yes, there’s a known problem with some older Nvidia drivers. I’d suggest you update your video card drivers when you get a chance. No rush, though, you don’t lose anything by running without OpenGL (except OpenGL, of course).
