When should we use disable resample and smart resample?
Posted by Tony Greco on February 25, 2019 at 7:11 pmWhen should we use disable resample and smart resample?
Tony Greco replied 7 years, 7 months ago 3 Members · 3 Replies -
Francois Pénzes
February 25, 2019 at 9:57 pmHi Tony
…and another one here:
https://www.vegascreativesoftware.info/us/forum/disable-resample-what-exactly-does-it-do–99420/
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Paul Berk
February 25, 2019 at 10:03 pmTHis is good stuff to learn if you are doing really quality work ..
but for many of us here, you can also just leave the defaults in project properties for the type of footage you are using. I wouldn’t change the defaults unless you have a reason and understand what it will do.
Tony Greco
March 2, 2019 at 6:12 pmStill a bit confused.
If my frame rate is the same in settings, source, and final render should I use smart re-sample or disable it?If my project has clips with different frame rates should I use resample or disable?
If I’m making a clip slower for slow motion should I resample or disable?
And If I’m adding fx should I?
That’s all I need to know.
