Activity Forums Apple Final Cut Pro Legacy When should I choose DV-NTSC Anamorphic for capture?
  • When should I choose DV-NTSC Anamorphic for capture?
    Posted by Dan Spezz on April 26, 2010 at 12:02 am
    If I set my DV cams to record widescreen 16:9, do I need to select the DV-NTSC Anamorphic capture setting, or is that setting used only for taking standard 4:3 footage and making it widescreen aspect ratio?
    David Battistella replied 16 years, 5 months ago 2 Members · 1 Reply
  • David Battistella
    April 26, 2010 at 3:44 am
    You could set it to anamorphic on capture or you could just check the checkbox in the file browser after the fact as well.
    david
    Peace
