Activity › Forums › Adobe Illustrator › When saving JPG file the file turns blue!
  • When saving JPG file the file turns blue!
    Posted by Lauren on June 29, 2006 at 8:15 pm
    I have no idea what is going on, but when I save things in illustrator as jpg file format the backround and the graphic turns blue. I can save as other files fine, but not jpg. I would just save it as another file however the program I am putting the image into requires jpg for some reason. PLease help ASAP if you can. Thank you in adavance!
    Mike Gondek replied 20 years, 2 months ago 2 Members · 1 Reply
  • Mike Gondek
    July 11, 2006 at 6:26 pm
    What happens if you save form illustrator as .tif and then in phothsop do a save to .jpg. Try use save for web from illustrator and choose jpeg there.
    I have seen white backgrounds chaneg to blue due to an incorrect color mangement setup, but not the entire document. Do your images look like blue monotones. I would turn off color management temporarily and see if your problem continues.
