Activity Forums Adobe Premiere Pro when linking after effects projects in adobe premiere pro CS3 playback issues
  • when linking after effects projects in adobe premiere pro CS3 playback issues
    Posted by Dax Coley on July 4, 2011 at 6:58 am
    This is my first post here on Creative Cow.net. I’m currently using Adobe Premier Pro CS3 and linking to a After Effects project which is from the same creative suite. The link project plays in Premier terrible. I know the premier and after effects deal with color differently yuv vs rgb. I even render out a tiff sequence and still having some choppy playback. Any one has gotten any ideas?
    Thanks for whatever anyone can think of in advance.
    Mike Cumberworth replied 15 years, 2 months ago 2 Members · 1 Reply
  • Mike Cumberworth
    July 8, 2011 at 5:10 pm
    Have you rendered the project within Premiere (hit “Enter”) to see if that helps? Could just be a function of your computer being unable to keep up w/realtime playback, especially if it’s a large project.
    If not that, maybe there’s a difference in project settings between Premiere & After Effects (different frame rates, progressive vs interlacing, etc) or how the AE footage is being interpreted in Premiere (right click -> Interpret Footage)?
    If your computer is older, has limited RAM, or if it’s a big file, it still might have problems. Mine running CS3 on 32-bit Windows would choke on anything larger than 720×480 & often failed to render due to running out of available memory. Dynamic Link was pretty much out of the question (& I think it was generally problematic in CS3). Seems to run much better using CS5 w/64-bit Windows. Maybe time for an upgrade 🙂
    Good luck!
    ~ Mike
