Activity Forums Sony Cameras When I’ve wiped an SXS card, should I format it every time?
  • When I’ve wiped an SXS card, should I format it every time?
    Posted by Richard Doyle on October 19, 2010 at 6:31 pm
    Whenever I finish with a CF card in the 7D, I wipe it completely and then format it. Should I do the same with 32Gb SxS cards from the EX3? Are there any drawbacks to this? Could it damage the card?
    Ronnie Martin replied 15 years, 8 months ago 7 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    October 19, 2010 at 6:34 pm
    No damage at all, but is unnecessary.
    Just “Delete all clips” on camera.
    rafael
    http://www.nagavideo.com
  • Richard Doyle
    October 19, 2010 at 6:37 pm
    If I don’t format the card, wouldn’t that potentially leave old information on the card that I don’t need (old folders etc), which could cause a problem down the line? I’m hearing conflicting messages on this. The way I see it, if you format it every time then you’re starting with fresh cards on each shoot, and you’ve lowered the chances of something going wrong when importing. Or maybe I’m being overly cautious?
  • Ian Cook
    October 19, 2010 at 7:32 pm
    Hi Richard,
    When you ‘Delete All’ you erase all files and folders (remember the folder naming below CLPR is keyed to the titles of clips that you record) so it is in most cases the same thing as re-formatting. All that will remain after a ‘Delete All’ is the basic BPAV/CLPR/TAKR directory structure with no file contents.
    The one really significant difference is that if you format you also delete any picture profiles you have stored, since formatting wipes the whole card and not just the Clip folders.
    Cheers,
    Ian
    Ian Cook
    Sony Broadcast and Professional Company
  • Ron Pestes
    October 19, 2010 at 8:05 pm
    Also, if you have named the card you will have to rename it after formatting.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • Brent Dunn
    October 22, 2010 at 3:59 pm
    Formatting will also increase the wear and tear on your card, possibly decreasing it’s life expectancy…in theory.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1, V1U
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
  • Richard Doyle
    October 22, 2010 at 4:01 pm
    Are you sure about that?
  • Ian Cook
    October 22, 2010 at 4:13 pm
    It’s a ‘Quick’ format and only deletes the file allocation table so it’s questionable that it would have an adverse effect on the life of the card.
    Ian Cook
  • Bob Jackson
    October 31, 2010 at 4:46 am
    I accidentally erased all clips on the wrong card in the camera.
    Using a program called Treasured I recovered some/most of the files.
    The card is not formated completely in the camera.
    vidiot
  • Ronnie Martin
    December 23, 2010 at 3:18 pm
    How about the PMW 320? In the menu I have not found “delete all clips” like it is on the EX-1 and Ex-3. Anybody found the “delete all clips” in the menu?
    Ronnie Martin
    Ronnie Martin
    Kato Video Productions
    http://www.dirtracingvideo.com
    http://www.ramtv.tv
