Activity › Forums › Adobe After Effects › When is a good moment to render a comp to add effects to it and proceed to the last render?
  • When is a good moment to render a comp to add effects to it and proceed to the last render?
    Posted by Felipe Prado on July 17, 2019 at 10:22 pm
    When is a good moment to render a comp to add effects to it?
    To give you an example, let’s say I make a comp, and inside that comp I have this really big animation, it contains a lot of layer and all of them are white, because later I will add color to it, will add other effects and stuff, my question is, when should you jump to that stage, to colorize it and add other effects, also considering I will be using 3D and camera on it!
    Let me know thanks in advance!
    Walter Soyka replied 7 years, 2 months ago 2 Members · 1 Reply
