Activity Forums Adobe Photoshop When I Use the Line Tool….
  • When I Use the Line Tool….
    Posted by Mahmud Khan on October 31, 2006 at 11:48 pm
    When I use the line tool, a new layer is automatically created. I don’t particularly mind this. However, I can’t see what’s in any other layers I’ve created. The eye button is on so theoretically I should be viewing all other layers.
    I want to be able to make new lines within the same layer, or, failing that, be able to view the contents of pre-existing layers. Thanks in advance.
    Andrew Kramer replied 19 years, 10 months ago 2 Members · 1 Reply
  • Andrew Kramer
    November 3, 2006 at 5:42 pm
    If you hold down shift when creating filled-vector lines it will add the shape to the same layer.
