Activity Forums VEGAS Pro when i render my montages everything is full screen except the noise textures etc..
  • when i render my montages everything is full screen except the noise textures etc..
    Posted by Joran Vloeihjfs on January 6, 2011 at 9:50 pm
    what to do now because when i render it and watch it back the effect are only at the middle of my screen not at the sides my clip is but the effects aren’t
    with friendly regard,
    joran
    Jeremy Rasnic replied 15 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Rasnic
    January 7, 2011 at 3:16 am
    Out of curiosity, before you applied your noise textures did you set your project settings to be the same as your render settings?
    If not, see what dimensions your project is set to, adjust them to match your render settings.
    I had a similar issue with the Text GM’s when I accidentally was editing in standard DV instead of HD. It caused my settings to be off as the GM’s were createad with Standard Def dimensions.
    j razz
    https://www.jrazzcreations.com
