Activity › Forums › Apple Final Cut Pro Legacy › When I import footage, I’m finding the clips are panned all the way to -1. Why?
  • When I import footage, I’m finding the clips are panned all the way to -1. Why?
    Posted by Noam Osband on June 27, 2011 at 5:30 pm
    When I import footage and I open the files, I’m finding that the audio is panned all the way to -1. This is annoying when it’s stereo audio and i’m mic’ing two different people. Do I have some setting wrong? Why do I have this problem?
    Michael Gissing replied 15 years, 3 months ago 3 Members · 4 Replies
  • James Bayliss-smith
    June 28, 2011 at 2:31 am
    What camera, what format etc…
  • Michael Gissing
    June 28, 2011 at 2:48 am
    When you capture audio as stereo, you get a linked 2 channel file with ch 1 panned to left and 2 panned to right.
    Change your capture setting to mono audio and the tracks will be panned center. The fix for your existing material is to select, unlink, Modify> Audio> pan center.
  • Noam Osband
    June 28, 2011 at 5:55 am
    On my capture settings for Log and Transfer with an AVCHD card, I want to say I can only do regular stereo and matrix stereo. Mono is not an option. I’ve never seen it as one before. Am i wrong?
  • Michael Gissing
    June 28, 2011 at 7:12 am
    Log & Transfer may be limited. Log & Capture gave you that option.
    So just do the unlink & pan trick. You can relink afterwards if you want.
