Activity Forums Apple Final Cut Pro When I export to XML, is FCP X adding to clip length??
  • When I export to XML, is FCP X adding to clip length??
    Posted by Noam Osband on December 4, 2018 at 11:14 pm
    I’ve been editing podcasts using FCP X. I set them up in FCP X, and then I export to Logic for fine tuning and mixing.
    It works great, but I’ve noticed sometimes when I export, it seems like FCP X is adding tails to the clips, so when I go through, there are some added “umms” or “uhhs” that I’ve taken out but are now in the session when I open it in Logic. Does FCP X do that? Can I change that?
    Noam
    Jeff Kirkland replied 7 years, 9 months ago 2 Members · 1 Reply
  • Jeff Kirkland
    December 9, 2018 at 8:15 pm
    FCPX doesn’t add any handles to your edits – I’d think it’s more likely that Logic isn’t interpreting the cuts as precisely as FCPX.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
