Activity Forums Apple Final Cut Pro Legacy when i drag a clip from one sequence to another, it’s not snapping directly to the clip i want it to. Why?
  • when i drag a clip from one sequence to another, it’s not snapping directly to the clip i want it to. Why?
    Posted by Noam Osband on August 26, 2011 at 4:28 pm
    I’m dragging clips from one sequence to another. I have on snapping and, before letting go of the mouse and depositing the clip, it seems like it going to snap. however, once i let go, there is a small space between the clip and the clip I thought it would snap next to. Why?
    Noam Osband replied 15 years, 1 month ago 3 Members · 3 Replies
  • Dan Blaim
    August 26, 2011 at 5:58 pm
    I have noticed this when I copy clips from a 23.98 timeline into a 29.97 timeline. Could this be your case?
  • Jeff Meyer
    August 26, 2011 at 10:23 pm
    Not as direct – but what happens if you drag to the Viewer and then back down (or to the appropriate Canvas).
  • Noam Osband
    August 27, 2011 at 3:40 pm
    Dan got it right. I had sequences of different frame lengths. Thanks!
