Activity Forums Apple Final Cut Pro Legacy When connecting Scratch disk to another computer, the Rendering vanishes
  • When connecting Scratch disk to another computer, the Rendering vanishes
    Posted by Nhan Nguyen dinh on November 11, 2011 at 3:56 pm
    Hello
    On the MacBook Pro I works with an external drive LaCie as Scratch disk.
    After the Render All of my Project, I connect my Scratch disk LaCie to my Mac Pro.
    On the Mac Pro, I open LaCie >>> open my Project and I notice that my Project need to be Rendered again : the most upper bar of the TimeLine is red.
    My request is ;
    When I connect my Scratch disk to another computer, how can I do to maintain the same Render (I mean for not Rendering again)
    Thank you very much
    Best regards
    Nhan
    David Roth weiss replied 14 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Neal Broffman
    November 11, 2011 at 5:54 pm
    Check your system settings in FCP to ensure that your render files are also going to the same drive as your video capture. In this case, your Lacie.
    Neal Broffman
    One Production Place, Atlanta, GA
    http://www.oneproductionplace.com
    Latest project:
    Series of profiles for the Paul and Daisy Soros Fellowships For New Americans.
    https://vimeo.com/channels/pdsoros
  • Shane Ross
    Make darn sure that you are indeed rendering to that drive. Check the CAPTURE SCRATCH settings on the original machine. Sometimes it’ll switch to your internal drive (if you launch FCP without the external connected, for example).
    Shane
  • David Roth weiss
    November 11, 2011 at 6:16 pm
    Which version of FCP are you using Nguyen? FCP version 7 is really the first version in which render files could be moved seamlessly between computers. With FCP 5 or 6, render files seldom came across as expected when copied to another drive, unless Media Manager was used in the process.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Nhan Nguyen dinh
    November 11, 2011 at 6:39 pm
    Hi David
    Thanks you for your informations.
    I use FCP7 always updated.
    Nhan
  • Nhan Nguyen dinh
    November 11, 2011 at 6:42 pm
    Thank you very much for your advise.
    The render files are in MacBooPro, but I have copied the Render document in the LaCie before disconnect it from Mac Book Pro to bring it to my Mac Pro.
    Best regards
    Nhan
  • Shane Ross
    November 11, 2011 at 6:47 pm
    OK…they are on the internal drive. Meaning the project is linking to them on the internal. You need to RE-LINK to them on the external…preferrably before you copy the project file and hand off the drive. Copy them to the external, remove them from the internal (they shouldn’t be there in the first place), reconnect…save, then hand off.
    Shane
  • Nhan Nguyen dinh
    November 11, 2011 at 6:51 pm
    Hi Shane
    Thank you for all informations.
    I launched FCP7 WITH the external drive LaCie connected. But I notice that the Render document is in my Internal drive. Noticing that, I copied the Render document to the external drive LaCie before bringing it to my Mac Pro.
    After me logically, ti must work, but i did’nt.
    Best regards
    Nhan
  • David Roth weiss
    November 11, 2011 at 6:56 pm
    Time to learn the Media Manager copy function. Do a search of this forum and you’ll find several of my explanations of how it’s used.
    David Roth Weiss
    Los Angeles
