Activity › Forums › VEGAS Pro › What’s the value in converting VOB to AVI versus MPEG2?
  • What’s the value in converting VOB to AVI versus MPEG2?
    Posted by Jack on May 19, 2005 at 9:29 pm
    I’ve been converting my wedding DVD from VOB to AVI and have noticed that the files are enormous. I’ve also recently started to convert them to MPEG2 and the files are smaller and take less time to convert. What’s the value of each of these file formats for video editing in Vegas and processing in Architect?
    Jack
    Rob Mack replied 21 years, 4 months ago 4 Members · 4 Replies
  • Andyb
    May 20, 2005 at 1:03 am
    A VOB, if built for a standard dvd is a mpeg-2. Ya, to convert one into an AVI, use divx or xvid (mpeg-4) for a smaller file size. Im assuming when YOU say AVI you mean DV ntsc which doesn’t use heavy compresssion therefore is a larger file size. The value of converting a VOB to a DV ntsc AVI would be to edit it I guess. If the dvd was built with dolby auidio then you would need a utility to convert back to a mpeg 2 with an audio stream, can’t really help with that. If it uses PCM audio then you should be able to just rename the files extension to .mpg. It is already an mpeg-2. I rambled sorry if I wasn’t much help. GL 😛
    -Andy B.
    http://www.avclubfilms.com
  • Jack
    May 20, 2005 at 5:19 pm
    To clarify this post. What I wanted to know was in terms of editing in Vegas, which is better: AVI file format or MPEG2 File format.
  • Edward Troxel
    May 20, 2005 at 5:51 pm
    DV-AVI is much better for editing than MPEG2.
    Edward Troxel
    JETDV Scripts
  • Rob Mack
    May 20, 2005 at 11:35 pm
    In fact, after trying to edit mpeg2 for a minute, you may decide to call it impossible.
    Rob Mack
