Activity › Forums › Adobe Premiere Pro › What’s the point of the work area?
  • What’s the point of the work area?
    Posted by Dustin Parsons on March 9, 2012 at 8:34 pm
    Hey there, another FCP user confused with an aspect of Premiere. I’m trying to determine what purpose of the Work Area is other than to define a section of the timeline to render or export?
    Joseph Mastantuono replied 14 years, 4 months ago 5 Members · 5 Replies
  • Chris Tompkins
    March 9, 2012 at 11:20 pm
    That is the main point. To select only a portion of the entire sequence for rendering or exporting. Rendering being the biggest I would think.
    Chris Tompkins
    Video Atlanta LLC
  • Dustin Parsons
    March 9, 2012 at 11:31 pm
    Lame, that just adds unnecessary clutter to the interface when a simple in and out selection would suffice perfectly – please correct me if I’m wrong though. Does anyone prefer to use the work area method over in and out points?
  • Paul Neumann
    March 10, 2012 at 12:37 am
    You can mark in and outs on your timeline to mark a specific area, and then jump to the in and out using Q and W respectively. The cool thing about the render bar is how easy it is to set. Double click in the light grey strip where the bar is and it will automatically mark the section that’s filling the window or if the entire timeline is visible it will mark your entire piece and it’s ready to render. Can’t tell you how many times I’ve double clicked and it put an end point way out past the end of my timeline because I had left a stray bit of audio or a few seconds of graphic hanging out there.
  • Chris Borjis
    March 19, 2012 at 6:07 pm
    I don’t like the work area either.
    I went to render out a specific section of a video
    (had marked it in and out) and it was exporting the whole thing.
    it shouldn’t do that.
    I suspect CS 6 will take care of that aspect.
    Adobe has worked really hard to make it easier to use
    for those of us coming from Avid / FCP
  • Joseph Mastantuono
    May 10, 2012 at 6:05 pm
    Just turn the Work Area off.
    Joseph Mastantuono
    http://www.goodpost.net
    Color Grading & Post Production Consulting
