Activity › Forums › Adobe After Effects › What’s the keyboard short-cut to toggle auto-keyframe on and off?
  • What’s the keyboard short-cut to toggle auto-keyframe on and off?
    Posted by Paul Boone on January 25, 2012 at 5:01 pm
    toggle auto-keyframe shortcut? I know its the letter “a” in motion 4
    how do I modify keyboard shortcuts? and i assume in the same place I can see all of them. I have the manual that lists them, but can’t find “auto-keyframe”
    Ben G unguren replied 14 years, 8 months ago 3 Members · 2 Replies
  • Michael Szalapski
    January 25, 2012 at 5:49 pm
    This page tells you how to modify keyboard shortcuts: [link]
    I don’t believe there is a keyboard shortcut to toggle Auto Keyframe mode, but there is a button to turn it on and off: [link]
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Ben G unguren
    January 25, 2012 at 10:05 pm
    I’m not sure how auto-keyframing works in Motion, but keep in mind that in AE keyframes will ALWAYS be created for attribute that already has a keyframe on it, regardless of whether auto keyframe is on or off.
    When auto keyframe is on, the modification of any property (scaling a layer) will create a keyframe, even if no keyframes existed before.
    This behavior is different from a lot of 3D apps, which will not create a keyframe even for a property with existing keyframes unless auto-keyframe is enabled….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
