Activity › Forums › Storage & Archiving › What’s the fastest read and write speeds I can get, internal or external to a Mac Pro – on budget
  • What’s the fastest read and write speeds I can get, internal or external to a Mac Pro – on budget
    Posted by Terry Flaxton on August 17, 2012 at 11:23 am
    I last specked a mac 12 core with 3 internal hard drives – at that point I could play back Red’s 4k r3d files. But since then SSD’s have come into play. Should I put three ssd’s inside a mac and if so what speed read and write will I get? Or should I buy an external raid carrier – like sonnet and connect via esata at 3gig (or thunderbolt) and yes, budget is always limited so I need a best-buy option. By buying 2 quad sonnet boxes in the past and going in via esata I got about 500MB read and write – had I doubled the drives I would have got 900 or so. But I now need a lot of read write in Raid 0 as I’m in 3D at 4k. Any ideas?
    A long term DP – likes 35mm and HD equally – changing with digital media – Began as a commercials editor !
    Rainer Wirth replied 13 years, 10 months ago 4 Members · 5 Replies
  • Alex Gerulaitis
    August 17, 2012 at 12:42 pm
    [Terry Flaxton] “had I doubled the drives I would have got 900 or so”
    Not if you were working with only two 3G eSATA interfaces – those max out at about 275MB/s each.
    If you need/ want over 550MB/s, eSATA is far from the best choice. An 8-bay MiniSAS box with a controller can be had for about $1K – $1.5K before you add drives, and give you close to 1GB/s speeds with the right drives.
    Alex Gerulaitis
    Systems Integrator
    DV411 – Los Angeles, CA
  • Terry Flaxton
    August 17, 2012 at 2:49 pm
    By mini sas controller, do you mean a card that takes in the output of the min sas box? Sorry, I’m unfamiliar with this stuff (also, previously I had a card with 4xesata in)
    Best Terry
  • David Gagne
    August 17, 2012 at 8:39 pm
    For best performance, get a SAS card like this:
    https://www.promax.com/p-781-atto-expresssas-r380-sas-raid-card.aspx
    And hookup some storage like this:
    https://www.promax.com/s-67-fastmaxfx8.aspx
    Should see 700-900MB/s…
    For more speed get a bigger box like this:
    https://www.promax.com/s-69-fastmax-fx16.aspx
    ~1000MB/s
  • Terry Flaxton
    August 18, 2012 at 12:09 pm
    Thanks for this – but: has anyone any specs on internal raid 3 x ssd’s read and write even if it’s just using a Kona tool. My current 3 x 2T hard drives read about 340 MBs – -so what do 3 x ssd’d do?
    Thanks for all answers up till now.
  • Rainer Wirth
    November 13, 2012 at 4:00 pm
    I go with Alex,
    and I don’t think you get more than 500 MB/s speed out of an SSD array. But you can try. Interesting. Tell us, how it works.
    Rainer
