Activity › Forums › Apple Final Cut Pro Legacy › whats the difference between 1080i60 and 1080i50?
Posted by Brydie Sheen on March 14, 2009 at 3:19 ami have a canon xha1 and not sure what to set my sequence/capture/device control presets to when logging/capturing.
then there is the problem of exporting to quicktime and what settings to use here??
what is the difference between the 50 and the 60 (1080i).
also how do i know if it is recording at 24/25 fps and does this affect my presets??
ive burnt to a dvd but the HD quality on dvd just isnt the same quality definition as the original tapes (rushes). In fact -it looks HORRIBLE!!
what am i doing wrong??!!
brydie
What Now?
Adrienne Grierson replied 17 years, 4 months ago 5 Members · 12 Replies -
Tom Wolsky
March 14, 2009 at 3:31 amWhere are you? 50 and 60 define the frame rate. What you shoot determines what preset you use.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Michael Sacci
March 14, 2009 at 3:36 am50i is a PAL framerate (non North America)
60i is NTSC framerate.[Brydie Sheen] “also how do i know if it is recording at 24/25 fps”
May want to crack open the manual for the camera for that.[Brydie Sheen] “ive burnt to a dvd but the HD quality on dvd just isnt the same quality definition as the original tapes (rushes). In fact -it looks HORRIBLE!!
what am i doing wrong??!! “
If you state what you are doing it maybe easier to give advise. -
Brydie Sheen
March 14, 2009 at 3:38 amI forgot to add in my last post this is what my xha1 is set to:
comp. output: 1080i/576i
frame rate: 50i
signal: HD
image size: LW1920x1080can you advise me of what my presets should be on for log/capture and what firewire setting i should have? then what settings for converting to quicktime?
ive been playing for a couple of days but the final quality on dvd is horrible and my boris text keeps jittering!
thanks!!!
What Now?
Brydie Sheen
March 14, 2009 at 3:40 amoh. now i remember…it was in there somewhere!! that means i never touch 60i!!
one problem solvered!
ta 🙂
What Now?
Brydie Sheen
March 14, 2009 at 3:46 ami actually dont think i know what im doing!! makes it hard to explain!!
comp. output: 1080i/576i (what does the 576i mean)??
frame rate: 50i
signal: HD
image size: LW1920x1080i imported my xha1 to FCP footage under presets:
sequence: HDV 1080i 50
capture: HDV
Device control: sony HDV 1080i 50 fire wire.it all seems to go to shit in the export from FCP to quicktime.
I have tried exporting and experimenting with different settiings as quick time movie and quick time conversion. either the images jitter/or the crawling text jitters.does this help you….to help me?!
What Now?
Michael Sacci
March 14, 2009 at 7:20 amI’m assuming you are in PAL land. 50i
Out of FCP if you Export to a quicktime movie for encoding make sure the “Current Settings” is what is selected but…
especially with HDV footage I found that if you export your timeline – Export> Using Compressor. This will send your seq to Compressor, there select the PAL DVD preset. give me the total length of all the video that will be on the DVD and I can suggest a bitrate.
The way is the slowest way to encode and it ties up Compressor and FCP for the entire process but you should see much better quality.
Brydie Sheen
March 14, 2009 at 7:31 amyes – PAL land!! down under 🙂
it is roughly 3 minutes in length! not much at all.
im so used to working in SD. this is the first time ive tried to export HD to quick time and burn to dvd.
do you think because im using iDVD this may be affecting the quality/final product? i seem to be getting artifact in the iDVD process as well!!
What Now?
Michael Sacci
March 14, 2009 at 8:04 amOkay, for that short definitely do what I posted above. Export> With Compressor.
Make a new m2v preset in Compressor
File Format: MPEG-2
Extention: m2v
Stream Usage SD DVDSettings:
VIDEO FORMAT TAB
Video Format: PAL
Frame Rate: 25
Aspect Ratio: 16:9
Field Dominance: UpperQUALITY TAB
Mode: One Pass CBR
Average Bit Rate: 7Mbps
Max. Bit Rate: will be grayed out
Motion Estimation: Good (does not come into play)Leave GOP and EXTRA tabs as is.
Then use one of the Dolby Digital Professional 2.0 presets for the audio.
Encode this and you will have an audio and video file to bring into DVDSP, author a simple DVD with that. Stay away from iDVD if you want better quality.
David Roth weiss
March 14, 2009 at 3:16 pm[Brydie Sheen] “do you think because im using iDVD this may be affecting the quality/final product?”
There is a reason Apple calls the applications in Final Cut Studio “pro apps.”
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Brydie Sheen
March 14, 2009 at 9:16 pmi think the main prob has been my import settings…..i’ve spent the last 24 hours exporting to DVDSP as Mpeg2 conversions and DVPAL and others!!!!
All round Mpeg2 had an average quality (much definition lost). Qtimepro conversion to DVPAL rendered/compressed boris text to look A class super hot. Unfortunately the DVPAL export didnt do the original footage any justice. While it looked HD on my DVD burn/TV, but people in shot were pausing/jumping etc..
I cant use compressor either because it wont SUBMIT anything!!!!!!
I think my main problem may be in my import settings…..grrrrr so will have to redigitise under prores instead of HDV….and try all this again.
fingers cross this works!! Well, at least ive learned alot.
goodluck anyone moving from sd to hd (canon xha1)!!!
What Now?
