Activity › Forums › Apple Final Cut Pro Legacy › What’s the deference between Konna 3 and LHi
Posted by Salah Elfalahi on October 21, 2009 at 7:36 pmHi all
My main reason to buy one of them is to monitor color grading and down scale full HD to SD to get the best possible quality. i never work with higher than full HD. is LHi enough for me ? and if you could be kind with me and tell me what’s the deference between Kona 3 and LHi.
By the way i went through their website but i couldn’t comprehend most of the terms as i never worked with uncompressed stuff….
thanks very much
salahSalah Elfalahi replied 16 years, 10 months ago 5 Members · 11 Replies -
Jonathan Lakser
October 21, 2009 at 7:47 pmkona 3 will only do analog audio monitoring if you buy the kbox
John Fishback
October 21, 2009 at 7:58 pmI’m not an expert, but I believe the main difference is the Kona 3 has mainly digital ins and outs – HD-SDI & SDI for video and AES for audio (although, there are two analog audio RCA outs and a component/composit/s-video out); and the LHi adds more analog I/O and HDMI. The Kona 3 can also deal with Dual-Link and 2k.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Walter Biscardi
October 21, 2009 at 8:06 pmKona 3 has a few more inputs and outputs.
Kona 3 supports 2k workflows which the LHi does not.
Kona 3 support Dual Link uncompressed HD which the LHi does not.
For the base features, they are pretty much the same. Up / Down / Cross Conversion are standard on both.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Salah Elfalahi
October 21, 2009 at 9:05 pmthanks walter
now i understand that i dont need kana 3 as long as i dont work with 2k and LHi is enough to down convert full HD to SD. but, i only have Sony HVR-M15AE HDV Deck (fire wire) input, what else do i need to be able to capture from the LHi card into my deck (as far as i know there is no fire wire output from LHi ?
thanks -
Walter Biscardi
October 21, 2009 at 9:09 pmIf you truly only have Firewire input to your deck, you will not have any need for the LHi as that deck will destroy any quality gains by compressing your footage back to HDV. There is no Firewire output on the LHi, only via the Mac.
Salah Elfalahi
October 21, 2009 at 9:41 pmPlease Walter, what do you understand from this info below which talk about my Deck Video input/output, as i’m only using firewire so far;
Video input/output
RCA x 1 / RCA x 1
[1Vp-p , 75ohm unbalanced, sync negative
Sync signal : 0.286Vp-p (50i / NTSC) , 0.3Vp-p (60i / PAL)
Burst signal : 0.286Vp-p (50i / NTSC) , 0.3Vp-p (60i / PAL)
S-video input/output
Mini-DIN 4pin x 2
Y : 1Vp-p , 75ohm unbalanced, sync negative
Sync signal : 0.286Vp-p (60i / NTSC) , 0.3Vp-p (50i / PAL)
Chrominance signal : 0.286Vp-p (60i / NTSC),(burst, 75ohm) , 0.3Vp-p (50i / PAL),(burst, 75ohm)
Component video output
RCA pin x 3
Output at 480i NTSC
With[BETACAM] selected in [480i LEVEL] of the [IN/OUT REC] menu
Y : 1 Vp-p (0.286Vp-p sync negative, output impedance 75ohm unbalanced)
Pb / Cb / B-Y , Pr / Cr / R-Y : 0.7Vp-p (output impedance 75ohm unbalanced) (75% color bar with 7.5% IRE setup)
With[SMPTE] selected in [480i LEVEL] of the [IN/OUT REC] menu
Y : 1 Vp-p (0.3Vp-p sync negative, output impedance 75ohm unbalanced)
Pb / Cb/B-Y , Pr / Cr / R-Y : 0.7Vp-p (output impedance 75ohm unbalanced)(100% color bar with no setup)
Output with other settings
Y : 1 Vp-p (output impedance 75ohm unbalanced)
Pb / Cb / B-Y , Pr / Cr / R-Y : 0.7Vp-p (output impedance 75ohm unbalanced)(100% color bar with no setup)
480i / 480p :
Y : with 0.3Vp-p sync negative
1080i / 720p :
Y / Pb / Pr : with 0.6Vp-p 3-level sync
i.LINK
6-pin
Digital uncompressed output
Phones
LANC
Stereo mini-minijack ( 2.5 mm)
Control S
Stereo minijack ( 3.5 mm)
Audio input
RCA x2,stereo
Input level : -10dBu, input impedance: min. 47 ohm unbalanced, max Input level : +18dBu (approx. 6Vrms) 60i , +16dBu (approx. 5Vrms)50i
Audio output
RCA x2,stereo
impedance : max. 1k/ohm unbalanced, Output level : -10dBu (=full bit -20dB) impedance 47 ohm unbalanced 60i, -10dBu (=full bit -18dB) impedance 47 ohm unbalanced 50i
LCD monitor
thanks
Walter Biscardi
October 21, 2009 at 10:02 pmYou have a choice of Composite analog or Firewire for input.
Shane Ross
October 21, 2009 at 10:54 pmCOMPOSITE out to the HDV deck? Ugh…yuck. That will look like CRUD. Firewire out…PRINT TO VIDEO. That will get you better results. ONly the 1500 deck has a good input option, SDI…but even then, there is some loss.
Shane
Read my blog, Little Frog in High Def -
Walter Biscardi
October 22, 2009 at 9:47 am[salah Elfalahi] “so LHi will do for me”
Yes on the composite video but that won’t be HD. It’ll be the worst possible quality SD you can record to tape.
For HD, your only option is Firewire.
