What’s the best way to work with high speed footage in Premiere? (from a Sony FS700)
Hey, Guys.
So I shot some cool stuff using the Sony FS700 hi frame rate capability. You can set it up to shoot 240fps which plays back at 1/10 speed. Very cool.
So I’ve got these great, HD, 1/10 speed files that I want to make my little movie with. I’d like the footage to play mostly at 100% of real time (so 1000% speed for the files the camera produces) and then just use the slow motion effects to highlight certain elements, ramping down and then back up again.
What’s the best way to do this? I’ve fiddled a bit with the Speed/Duration… dialog, but there’re no controls for ramping speed up or down there. Is there? I’ve also been trying out the Time Remapping, but I’m not sure if there’s a way to make the speed go over 100%.
What I’ve been doing today is making a rough edit, nesting that sequence, speeding up the resulting sequence to 1000% in Speed/Duration… which has the movie playing at a normal speed now. Then using the Time Remaping to slow down the parts I need in slo-mo.
How does this sound to you guys? It seems kind of klunky, and I’m concerned about a loss of quality somewhere. Is this the correct way to go or is there a better way of doing this?
Thanks so much!
Corbin Gross | SANMAR
Photographer/Videographer | Marketing
22833 SE Black Nugget Road | Issaquah, WA 98029
206.727.5501 x5237
http://www.sanmar.com
