What’s the best way to work with a project on multiple hard drives?
I have some small projects where all the exported footage is less than 200 GB. I usually use a G-tech drive but I like being able to edit sometimes in a coffee shop on a portable hard drive. What’s the easiest way to use the same library on two drives? Back with FCP 7, I would just have the media files on both drives and just copy the project file. It’s obviously not the same in FCP X. Thoughts?
