Whats the best way to use a mask to make it look like windows being cleaned?
Hi there
Basically Ive got an animation to do whereby a man is cleaning some windows and as he does, text is revealed. Now I guess using masks would be the best way to do this. But what is the best way to get the kind of edge and texture you would do when cleaning windows? I know you can use feathering, but I think itll look a little cheap……..any ideas would be much appreciated!
Also would you then use this mask as the position points for the mans hand so you dont have to animate all of his hand movements aswell?
Dan
