Activity Forums Adobe Photoshop Whats the best way to make sure a textured layer is only one colour?
  • Whats the best way to make sure a textured layer is only one colour?
    Posted by Daniel Haskett on November 20, 2007 at 2:30 am
    Hi there
    So basically ive got some textures, of paint, and then walls and various textures but i want to change their colours but so they are actually only 1 tone….like 1 colour. so no tonal variations at all….as though it were going to be screenprinted or something.
    i use gradient map generally as it has a lot to play with, however generally there is always a bit of tone left over…any tips on how best to achieve this would be much appreciated!
    Dan
    Richard Harrington replied 18 years, 9 months ago 3 Members · 2 Replies
  • Mike Jones
    November 27, 2007 at 9:24 am
    To get sections of images to adopt one colour, create a path or mask for the relevant part of the image.
    Create a new layer and fill it with the colour you want, use your path or mask to select the part of image you want to be coloured and delete/mask the rest.
    Finally (and the clever bit) go to the blending modes on your layers palette and change it from ‘normal’ to ‘colour’ and that should be the trick.
    You can do this with any colour, including Pantone references.
  • Richard Harrington
    December 2, 2007 at 5:39 pm
    Simply desaturate before adding gradient Map
    You can also change Gradient Maps blend mode
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
