Activity › Forums › Apple Final Cut Pro Legacy › What’s the best way to flip the image in FCP when using a 35mm adapter?
  • What’s the best way to flip the image in FCP when using a 35mm adapter?
    Posted by Pierre on July 21, 2006 at 2:57 am
    Currently using the HVX-200 and the Redrock adapter. Trying to figure out the best way to flip the image.
    Also, does flipping the image DEGRADE the image in ANY way?? Is it the same as color correcting or adding an effect?
    Thank you,
    Michael
    Ron James replied 20 years, 2 months ago 3 Members · 4 Replies
  • Pierre
    July 21, 2006 at 2:59 am
    I just flipped it within the WIREFRAME and litterally just dragged the image around until it was right side up. When I play back the footage I see bad interlace lines going across the image horizontally?
  • Ron James
    July 21, 2006 at 11:57 am
    I’m not sure how your image needs flipping, but try the Perspective filters – they’ll give you a better result. The image degredation depends on what codec you’re using. If it’s NTSC-DV (DV25) then there is recompression involved (just like adding an effect) but I’m not sure that it’s noticeable.
    HTH
  • Rick Dolishny
    July 21, 2006 at 12:45 pm
    Filters>Flop ?
    Rick Dolishny
    Discrete Editors COW Leader
    http://www.dolish.com – http://www.digitalimagefest.com
  • Ron James
    July 21, 2006 at 1:04 pm
    Yep, that’s the one. That should be easier and avoid any field problems.
