Activity Forums Apple Final Cut Pro Legacy Whats the best way to edit 1024×768 footage?
  • Whats the best way to edit 1024×768 footage?
    Posted by Milton Hockman on August 16, 2009 at 8:05 am
    WHat settings should i be using?
    My footage is Tutorial Screencasts at 1024×768 Animation Codec 15fps.
    Every setting i try is super slow on export. a QT ref is taking 20 mins for a 7 min rendered video.
    Motion Graphics Artist and Non-Linear Editor
    Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more.
    David Roth weiss replied 16 years, 8 months ago 3 Members · 2 Replies
  • Ben Holmes
    August 16, 2009 at 9:34 am
    Animation codec is a heavy duty high bitrate lossless codec used for exporting graphics elements with an alpha channel – it’s very hard to play it back on any system without rendering it out, and having it at 15fps is also a bit bizarre.
    If you just want to edit with it then transcode it using compressor into ProRes or similar. If you have FCP7, you can encode it as ProRes 4444 and keep the alpha as well. Unfortunately every method requires a render.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • David Roth weiss
    August 16, 2009 at 3:41 pm
    [Milton Hockman] “Every setting i try is super slow on export. a QT ref is taking 20 mins for a 7 min rendered video.
    Milton,
    It certainly sounds as if your timeline isn’t fully rendered before export, which does take longer because FCP is rendering and exporting simultaneously, rather than just rendering.
    So, make sure that “Full” is checked in the Sequence>>Render All dropdown menu, then re-render. Full is not checked as the factory default for some ridiculous reason, so you need to do it manually and check to make certain it’s checked in every new project.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
