Activity Forums Adobe After Effects Whats the best way to create a dust effect?
  • Whats the best way to create a dust effect?
    Posted by Accountneedsrealnameupdate on June 17, 2006 at 1:06 am
    I have an animation of a logo appearing to drop from above real fast and slam into the screen. Whats the best way to add a dust particle effect as if it fell on the ground and kicked up some dust?
    Jim Zito replied 20 years, 2 months ago 4 Members · 3 Replies
  • Andrew Kramer
    June 17, 2006 at 1:41 am
    Particle illustion would be best, I imagine.
    Andrew
  • Justin Productions
    June 17, 2006 at 2:56 am
    I did that several times with Trapcode Particular too.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Jim Zito
    June 18, 2006 at 8:04 pm
    tommmm,
    I just created the exact same effect using CC Particle World. Looked pretty damn good. Set the Particle Type to Darken & Faded Sphere, change the color to White, Grey, and/or Brown depending on your preference, and crank the Birth and Death Size up. Birth Rate, Gravity, Velocity, and Longevity are some other properties you may want to fiddle with too.
    Hope that helps!
    Jim
