Activity › Forums › Adobe After Effects › What’s the best way to convert frame rate and still keeping the audio in sync?
  • What’s the best way to convert frame rate and still keeping the audio in sync?
    Posted by Leah Stipic on July 27, 2010 at 8:12 pm
    I’m in the process of making a short film. It’s going to have a graphic novel style to it, but lots of it has been shot on green screen with real actors. I want to slow the framerate down slightly so it has a more animated feel to it. Right now it’s 25fps HDV720p. Any ideas on the best way to convert the frame rate on the video but still keep the audio in sync? And any suggestions on what frame rate would create the desired effect?
    Danny Hays replied 16 years, 2 months ago 2 Members · 3 Replies
  • Leah Stipic
    July 28, 2010 at 7:07 am
    We are trying to get it into festivals so there’s a chance it may have to be converted to film at some point. The output will be PAL DVD. I don’t think it will ever be for television broadcast, but I suppose if there’s a specific technique that allows it to work properly for all that would be best!
  • Leah Stipic
    July 28, 2010 at 4:29 pm
    Hi Dave,
    Thanks for your advice thus far!
    Keying hasn’t been too much of an issue, firstly because the green screen we shot on was well lit and the JVC studio camera was quite good, that combined with motions primatte it’s come out looking pretty good!! Luckily the overall style allows me to hide the edges a bit.
    As for the posterize time effect I did try that and it works, but not exactly in the way I hoped. I have played with the strobe effect in FCP/motion and I am now starting to get somewhere. I set it to 20 and then to 18 and it seems to be doing what I want now. As the characters are green screen I think you are right in not changing the frame rate… this way I can just effect the characters individually and not have to mess about with different frame rates until it’s absolutely necessary.
    Thanks again. Best,
    Leah
  • Danny Hays
    July 29, 2010 at 8:31 pm
    HDV may not be a great format to key, but I’v been able to get good keys with Keylight in AE and Ultra key can get a decent key from almost anything. Your lighting has to be done right though, even greenscren lighting, as much space as you can get between the subject and the screen to reduce spill and good back lighting, maybe the most important, in my opinion. Neoscene is a good intermediate format to key with. Hope this helps, Danny Hays
