Activity › Forums › Adobe Premiere Pro › What’s the best video bit rate for the web
Posted by David Dinenna on November 1, 2011 at 3:12 pmCan anyone tell me what the recommended video bit rate is for streaming mp4 video on the web?
Thanks in advance for any help.
Angelo Lorenzo replied 14 years, 11 months ago 3 Members · 6 Replies -
Angelo Lorenzo
November 1, 2011 at 6:19 pmNot exactly a simple question. What is the size and framerate of your video?
Is this a site for desktops/laptops or a mobile site?
Are you just simply uploading to Vimeo or YouTube?
Angelo Lorenzo
https://filmsfor.us – Helping you sell your film online
Watch Steve Job’s Spirit Inside The iPhone 4SSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Kevin Monahan
November 1, 2011 at 7:03 pmThere’s no single answer for that, as it depends on a number of factors. I suggest reading this article. It may be helpful: https://www.streaminglearningcenter.com/articles/streaming-101-the-basics—codecs-bandwidth-data-rate-and-resolution.html
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
David Dinenna
November 1, 2011 at 8:16 pmThe video size is 512 x 288 and will mostly be played on mobiles and tablets.
Angelo Lorenzo
November 1, 2011 at 8:45 pmWithout knowing the content of your video, I’d say between 1mbps and 2mbps will do the trick for that size. Easily above 3G speeds.
Angelo Lorenzo
David Dinenna
November 1, 2011 at 8:49 pmThanks Angelo. I usually use “Any Video Converter Professional” to convert video. Most of these are FLVs at 512 x 288 and aren’t too heavy with animation and graphic effects… really just talking heads. I’ve been using a video bit rate of 2500. After your response I’m thinking I must be doing something wrong because you’re saying to use a rate as low as 1 or 2.
What happens to a video with a video bit rate that’s too high?
Angelo Lorenzo
November 1, 2011 at 8:51 pmNo, you’re right there. I said between 1mbps and 2mbps and you’re saying 2500kbps also known as 2.5mbps. If you’re happy with those results for the amount of detail and motion in your shots, I’d say your initial estimates are on target.
Angelo Lorenzo
