Activity Forums Apple Final Cut Pro Legacy what would be the best procedure to prepare HD H264 and DVCPro Clips & what project settings to use to join all ?
  • what would be the best procedure to prepare HD H264 and DVCPro Clips & what project settings to use to join all ?
    Posted by Oliver Szymczak on April 16, 2012 at 2:00 pm
    okay, here is the scenario …
    I have to edit three different formats to be married in one timeline:
    H264 1280×720 50fps progressive (possible slomo …)
    H264 1920×1080 25fps upper
    DVCProHD 1080i50 1440×1080 25fps upper
    I suppose it will all be turned into ProRes …
    but what would be the right settings to go?
    is it best to scale everything down to the lowest resolution (1280×720)?
    or can the lower two be blown up to 1920×1080 (85% of the material is shot in that)?
    and what would be the correct pixel aspect ratio?
    the D5 and D7 have a 1.7777777
    while the DVCPro is 1.33333
    anyone out there that could give me a helping hand, please?
    Oliver Szymczak replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
