Activity Forums Apple Final Cut Pro What workflow do you suggest?
  • What workflow do you suggest?
    Posted by Larry Watts on February 2, 2014 at 2:57 am
    I’ve shot a simple cafe scene (dialogue) from three angles. Single camera, three separate clips. I recorded the audio on a Sound Devices 664 with three tracks: Lav 1, Lav 2, Boom mic.
    So, I started by editing the shots to the main storyline which are quick cuts of various angles. I’m wondering if I should have made the SD 664 audio the main storyline and edited to that.
    Any ideas as to best workflow?
    THX
    Larry
    John Fishback
    replied 12 years, 7 months ago
    2 Members · 1 Reply
  • John Fishback
    February 6, 2014 at 10:35 pm
    I’d marry the picture and sound for your bought takes and then use those to edit. You will have to balance the audio cut to cut, but that shouldn’t be a big deal. The only time I put audio in the primary is if all I’m doing is editing picture against a prerecorded track.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
