Activity Forums Adobe Premiere Pro What use are in/out points for sequences?
  • What use are in/out points for sequences?
    Posted by Choice49 on June 7, 2006 at 12:48 am
    Very NEWbie here. I have two 15-minute clips from two cameras that rolled simultaneously during a choir sing. These actually contained multiple “takes”.
    I followed instructions in “Classroom” and User’s Guide” and successfully made a multicamera sequence, synchronized by a handclap and edited to A or B roll appropriately. However, I only wanted the middle one-third or so, of these clips, for one particular take of a four-verse hymn (BTW I had only one good synch point, that handclap, at the beginning). So I set the multicam sequence’s In and Out points for the middle section I wanted to actually use.
    But when I drag this sequence into a different bigger sequence on the timeline, the entire 15-minutes is there, not just the part I want (as marked by in/out). This behavior is different from dragging clips onto the timeline, where the only stuff that “ends up there” is the part between in and out.
    Sure, I can instead trim the multicam sequence to my in/out points. But then I can’t easily go back and change my mind, like for instance use an entirely different “take” from the clips. I thought that was the main purpose of in/out points, namely that you can go back and fiddle with them, while preserving the entire clip for easy viewing in the source monitor.
    Seems I have to “hard-to-redo-or-fiddle-with” trim, where I really want to mark in/out. Or else I’m misunderstanding something fundamental. Why don’t in/out points work the same way for sequences as for clips, namely that they constrain what drags (and hence, renders in the project) to the timeline?
    Tim Roberts replied 16 years, 10 months ago 2 Members · 2 Replies
  • Choice49
    June 7, 2006 at 5:12 am
    Just to clarify, I may have misused the term “trim”, near the end. What I mean to say is that one workaround I can think of is to REMOVE (not trim) frames, by lift or extract I suppose, before and after my desired in and out points. And the disadvantage of this method is the permanence of such removal (as compared with merely setting in/out points like you do for a clip).
    Thanks for bearing with me, I was accidentally using the layman’s meaning for “trim”, i.e. “somehow cut away or get rid away”. But Premiere’s meaning for “trim” seems to be more like “hide”.
    BTW I do understand that even the above removal still isn’t quite an actual physical deletion of media. My point is that frames once removed from a multicam sequence aren’t easily returned, with switched edits and synchronization restored.
    All statements of fact are my humble impression based on just starting out. Please correct any errors of course. 🙂
  • Tim Roberts
    November 5, 2009 at 11:01 pm
    I have similar question — trying to add multiple clips to timeline from the same source using in/out pts– there are multilpe points in the source I want to add to the final
    Tim
