Activity Forums Panasonic Cameras What Type of Tape?
  • What Type of Tape?
    Posted by Tim Scarpino on August 9, 2005 at 12:33 pm
    I’ve seen much in several forums on the type of tape to use in the DVX100A.
    I’ve like to know what you all think. Why type of tape should I use?
    Also, do you use the Panasonic cleaning tape? Do you recommend it?
    Scott replied 21 years, 1 month ago 4 Members · 3 Replies
  • Anonymous
    August 9, 2005 at 8:23 pm
    panasonic master MQ is what I use.
    Pic a tape that you can easily get and afford and stick with it.
  • David Battistella
    August 10, 2005 at 5:44 pm
    Panny recomends their tape and I have never had any problems with their mastering series tape. I have had problems using other brands. Use their claning cassettes as well.
    Tape is cheap so I never buy cheap tape.
    David
  • Scott
    August 19, 2005 at 2:37 am
    Also, stick with one type of tape, Dry lube (MQ series) or wet lube (what you can buy at every electronics retailer). Make sure your cleaning tape is the same type also.
    Scott
