Activity Forums Adobe After Effects What transition plugin did they used?
  • Alexxx
    March 26, 2006 at 12:40 pm
    Hi Manny,
    Personally I think it was designed in a 3D application. It just seems that Belief have exceptional control over such elements as particles, 3D text, background etc which at that level would be very difficult in AE. Now, that’s not to say you cannot get something like this in AE. I would research Trapcode’s Particular as it would be able to easily create 3D lines that form a word and allow you to zoom around it with a camera. You could even fake the movie transition part by using the lines that Particular creates as displacement and then just fade across. I just think a 3D app will be able to go that extra mile to make that effect really shine.
    Alex
    http://www.lightdrop.com.au
  • Chris Smith
    March 26, 2006 at 4:36 pm
    To me this looks like the effect I see where they create a bunch of shapes in 3D like a cloud of cubes (or thin cylinders in this case) and project an image onto the shapes. Then bake the projection (or just use camera projection and parent the cam to the group so the texture locks to it). Then with a seperate cam shoot it from the exact angle from the cam projection then orbit around it. So that from the dead front it looks like a front image then as the cam flies away you see it break up into bunches of shapes in 3D.
    Here’s a tutorial on one person’s version of it using 3D MAX:
    https://www.happygraphics.net/goodies/stylewars%20tutorial/tut1.html
    Chris Smith
    https://www.sugarfilmproduction.com
