Activity › Forums › Adobe Premiere Pro › what to do when there is hiss on video?
Posted by Nitai Lev-oren on June 28, 2016 at 11:51 amI’m editing a presentation and the speaker have a hiss sound because the mic was to far or the volume on the camera was low I don’t know
how can I remove the hiss sound?Duke Sweden replied 10 years, 2 months ago 4 Members · 6 Replies -
Jerry Wise
June 28, 2016 at 4:51 pmYou could buy Wave Arts-Dialog plugin for Adobe Audition. It works well and is easy to use.
Duke Sweden
July 1, 2016 at 2:37 amSince I’ve already started enough threads here this week and my question relates to Adobe Audition I will add to this thread, as it also relates to the noise issue. I remember at one point, if I had noise, background hum, ambient noise, etc. I could go to effects>noise reduction/restoration>Capture Noise Print, followed by Noise Reduction (Process) after highlighting a portion of the timeline where only noise appeared, and when I applied Noise Reduction it would remove that sound from the whole audio track.
Now (and not just cc 2015.3 but even the previous version) it only removes it from the highlighted portion. If I un-highlight it, the noise doesn’t get removed at all. So I have to repeat the process for every section that has noise, which is a pain.
The same problem also exists if I use Learn Sound Model and Sound Remover (Process).
Any ideas?
Chris Wright
July 1, 2016 at 3:08 amaudition’s adaptive noise reduction will remove all noise at once.
Duke Sweden
July 1, 2016 at 1:51 pmI never question you, Chris, but I could swear I tried that last night before I put up my post. I’ll try again, just in case and report back.
