What to do about audio distortion
I recently finished a wedding video using Premiere Pro. I exported it to tape, which doesn’t reveal the points where the audio is too loud as does the DVD I just burned. At every point that the sound exceeds the normal parameters there is the harsh scratchy sound that indicates distortion from too loud audio. My question is what are my alternatives in this situation, if any? Can I go back through the project in Adobe Premiere and simply lower the volume at those points, then try burning another DVD? Or is there something I can do with the audio processing capabilities of Premiere Pro? Or can I import the sound into Adobe Audition and deal with it there? Or am I simply out of luck. I’d sure appreciate some advice on this.
Stem47
