Activity › Forums › Adobe After Effects › WHAT THE HELL!?!?!?!
Posted by Rj Hannigan on September 6, 2005 at 8:19 pmAfter Effects warning: Couldn’t open Quicktime video out put component.
What does this mean and how do I fix it?…just tried to render and I could’nt…please help I gotta get something out tonight!!!..
Joeythedog replied 21 years ago 4 Members · 5 Replies -
John Dickinson
September 6, 2005 at 8:28 pmSounds like you’re missing a codec. Have you received some footage from someone else that uses a codec you don’t have?
JD
John Dickinson
Motionworks
https://www.motionworks.com.au -
Rj Hannigan
September 6, 2005 at 9:02 pmno… its wierd its when i start up after effects the message pops up… and it pops op everytime i leave AE and go back to it… not techy at all… can i just throw away AE prefs and restart? and if i can how do i even do that?
Rj Hannigan
Jonathan Miller
September 6, 2005 at 9:17 pmAre you running AE at the same time as Final Cut Pro, or any audio program that uses the firewire output or any AJA or Decklink card? If so, then the solution is really simple (at least for me and my AJA Io):
When you leave AE, click on your desktop before switching to the other program, and do the same when switching from that other program back to AE. Clicking on the desktop switches to the Finder and releases the card or FireWire output from whatever is currently using it. It’s one little extra step, but works for me every time. You should also be able to do the same even after getting the warning. Just get rid of the Quicktime message, click on the desktop, then click back on AE. Might take a couple of tries, but it should work.
Good luck!
Jon
TreeLine Productions
Fort Collins, CO USA -
Joeythedog
September 7, 2005 at 6:25 amyou know — after reading this and what I’ve been through today with my computers THAT there is a huge consumer base ripe for the picking. I mean a large financial windfall to someone who wants to put out a platform like the Amiga. This frankenstein platform that is the PC is so patched together with DEAD body parts that it’s a real setup to get knocked off by something that works.
